reload playlist after this line
moogwill
Post by moogwill »
Hi Bernd, Here's a function that would probably very useful.
When a playlist was modified remotely, or when it's been saved after it was loaded in the scheduler, a right click on a track in the playing playlist, with an action called "relaod from this line" would be more easy than waiting for the playlist to update.. do you think that could be easy to do?
this function is implemented in a another software we use to to produce the local program of another radiostation, and it's an really useful and simple tool.
when you want to remotely change something at the last minute.
by the way that could be an option of the remote voice tracking tool, something like : "force update if playlist is running"
Thanks,
Thomas.
Re: reload playlist after this line
I guess this should be possible.
I’ll tale a look into it!
moogwill
Post by moogwill »
thanks
In v4.0.5.33 a related menu item (Check AutoWatch Playlist from here) was added to the Miscellaneous playlist context menu.
