Script Loop Line 0 and 1
jsonio
Post by jsonio »
I would like to understand the difference between Loop Line set to 0 and Loop Line set to 1 !
Thank you very much,
jsonio
Re: Script Loop Line 0 and 1
There is none;-) they are treated the same.
Inzane8305
Post by Inzane8305 »
If you mean "Is it on or off"? No thats not what it does. You set it to the line number you want the script to loop to when bottom reached.
A script always loops in case a playlist requests more tracks than available script-lines.
The LiopLine defines where to restart when looping.
A value of 0 means from the beginning. Any other value defines the line number. As every script starts with 1 this is also the beginning.
Therefor 0 and 1 are essentially the same!
