GPIO/Remoting Error changing from UDP to TCP in OSC
phonic
Post by phonic »
After changing from UDP to TCP in Open Sound Control and clicking to enable, I get the error below every time I restart ProppFrexx, and clicking continue closes the programme. I've disabled OSC for the moment so ProppFrexx can be used.
13-Apr-19 8:02:08 PM [v4.0.5.25]:********** Error/Exception Information **********
Error Message: The requested address is not valid in its context
Error Type: System.Net.Sockets.SocketException
Error Source: System.Void DoBind(System.Net.EndPoint, System.Net.SocketAddress)
at System.Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress)
at System.Net.Sockets.Socket.Bind(EndPoint localEP)
at System.Net.Sockets.TcpListener.Start(Int32 backlog)
at ProppFrexx.RemoteControl.Osc.TcpServer.Start()
at System.Threading.ThreadHelper.ThreadStart()
********** End **********
Re: GPIO/Remoting Error changing from UDP to TCP in OSC
Seems you have specified an invalid endpoint address?!
With what other device or software do you try to use OSC? As by default it should use UDP.
phonic
Post by phonic »
yes silly mistake. pointing to the wrong IP. I was able to change it while the error message was still on screen. I did not expect it would crash ProppFrexx though.
Yes, it shouldn’t - I’ll see to prevent this.
Should now be fixed in v4.0.5.27.
