"ANY OF"
moogwill
"ANY OF"
Post by moogwill »
In this case :
1 LeastRecentlyPlayed : ANYOF:/Hit, /News, /objectif, /Pop, /Power news, /quotas (Filter=~Contains([Grouping], 'Français') Or Contains([Grouping], 'français'), Options=None)
Is this gonna pick the least recently played file, from all folders, or will it pick a random folder, and play the least recentely played track from this particular folder???
I'would prefer the first solution, but as i can hear the result, I don't think it is. can you confirm ?
thanks.
Re: "ANY OF"
It will first pick a random media lib and then pick a last recently out of this.
moogwill
Re: "ANY OF"
Post by moogwill »
if the random lib got no track that match (because of history check for example), doest it skip the line??? cause it would be more logical to pick another lib...
I mean that I'd like to play a track grouping, regardless off the lib. the problem is that if the line is skipped; then I have no track at all (the oppsite of what I want)
Re: "ANY OF"
Currently you might use the UseLastTrackOnFinalFail script option or the SuppressHistoryCheck script-line option? But use the ForceLibraryHistory option etc.
However, it is currently not possible to first get the last recently used tracks out of all selected libs.
moogwill
Re: "ANY OF"
Post by moogwill »
I get it...
maybe that can be a futur option, if you think that can be implemented...
thanks
T.
Re: "ANY OF"
Yes, I’ll take a look what can be done.
