Unhandled Exception clicking on upcoming "upcoming overlays"
phonic
Post by phonic »
Unhandled Exception clicking on upcoming "upcoming overlays". blank white upcoming overlay window opens and this error box:
10/03/2019 00:22:44 [v4.0.5.8]:********** Error/Exception Information **********
Error Message: Cannot access the 'Reminders' property of a disposed object
Object name: 'Appointment'.
Error Type: System.ObjectDisposedException
Error Source: DevExpress.XtraScheduler.v18.2.Core.Void ThrowObjectDisposedException(System.String, System.String)
at DevExpress.XtraScheduler.Native.Exceptions.ThrowObjectDisposedException(String objectName, String propName)
at DevExpress.XtraScheduler.Internal.Implementations.AppointmentInstance.get_Reminders()
at DevExpress.XtraScheduler.Native.ReminderReadOnlyCollection.get_InnerList()
at DevExpress.XtraScheduler.Native.InnerAppointment.get_HasReminder()
at ProppFrexx.UpcomingOverlays.bKPL(Appointment )
at ProppFrexx.UpcomingOverlays.OKPf(Object , GetCustomNodeCellStyleEventArgs )
at DevExpress.XtraTreeList.TreeList.RaiseGetCustomNodeCellStyle(GetCustomNodeCellStyleEventArgs e)
at DevExpress.XtraTreeList.TreeList.InternalGetCustomNodeCellStyle(TreeListColumn column, TreeListNode node, AppearanceObject appearance)
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.CalcNodeAutoHeight(RowInfo ri, Int32 nodeHeight, IHeaderObjectCollection headers, Boolean even, Boolean includeColumnIndent, AppearanceObject additionalApp)
at DevExpress.XtraTreeList.TreeList.CalcNodeAutoHeight(RowInfo ri, Int32 nodeHeight, IHeaderObjectCollection headers, Boolean even, Boolean includeColumnIndent, AppearanceObject additionalApp)
at DevExpress.XtraTreeList.TreeList.InternalCalcNodeHeight(RowInfo ri, Int32 nodeHeight, Boolean useCache, IHeaderObjectCollection headers, Boolean even, Boolean includeColumnIndent, AppearanceObject additionalApp)
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.CalcNodeHeight(RowInfo ri)
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.GetTotalNodeHeight(TreeListNode node)
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.CalcVisibleNodeCountCore(TreeListNode topNode, Int32 height, Boolean down)
at DevExpress.XtraTreeList.TreeList.get_IsNeededVScrollBar()
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.CalcClientRect(Rectangle scrollRect)
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.CalcViewRects()
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.CalcViewInfo()
at DevExpress.XtraTreeList.TreeList.UpdateLayout()
at DevExpress.XtraTreeList.TreeList.LayoutChanged()
at DevExpress.XtraTreeList.TreeList.EndUpdate()
at ProppFrexx.UpcomingOverlays.YTW.DZ12()
********** End **********
phonic
Re: Unhandled Exception clicking on upcoming "upcoming overlays"
Post by phonic »
This is the second time the has happened, and had to restart restore upcoming overlay window otherwise it just gives an empty write box.
As the software is now live, I can't just keep restarting it all the time.
Any reason for this error?
phonic
Post by phonic »
No I don't use beta on a production system v4.0.5.8.
Managed to restart at 2am in a quiet spot an just had the same thing again:
10/03/2019 15:51:34 [v4.0.5.8]:********** Error/Exception Information **********
I am trying to reproduce it, but so far I was not able. I need to investigate, what might be causing this issue.
I am trying to investigate, but as this is a Beta-Version you are using, you might roll back to the last stable version!
phonic
Post by phonic »
For the moment I'm not clicking on this option in case it messes up the live system.
Should be fixed in the latest v4.0.5.17 update.
phonic
Post by phonic »
Just updated. Thanks for your help!
