Remote ONAIR viewer questions
phonic
Post by phonic »
Three questiuons with regards to the remote ONAIR viewer:
1, I’m using the remote ONAIR viewer in another studio while live streaming, and noticed song titles are not updated when it’s an internet stream. It stays on the first one when it first starts to stream.
2. Can you customise the layout? Disable some unneeded options?
3. Can the programme show the programme title not just the time and date?
Thanks for your time.
Re: Remote ONAIR viewer questions
1. Have you set (in ProppFrexx OANIR) the 'Update Stream Title in Playlist' option (general settings, section Playlist)?
2. No, this is not possible.
3. No, currently not.
phonic
Post by phonic »
Titles are updated correctly on ProppFrexx players as they change in the internet stream, but they stay fixed on the remote ONAIR viewer.
phonic
Post by phonic »
Just to add from my last post 'Update Stream Title in Playlist' is selected, and is showing correct titles coming from the Internet stream and displays correctly in ProppFrexx streams them correctly to our website stream and TuneIn, the issue is the Remote ONAIR Viewer only seems to update titles if it's not an internet stream. Is this a known bug?
Yes, I just looked at it. Mid-Stream title updates from playing URLs are currently not updated in the Remote Viewer - I'll change this with the next verison.
phonic
Post by phonic »
Thank you. Looking forward to it.
Fixed in the latest v4.0.5.17 update.
The current and last program names are now also shown.
phonic
Post by phonic »
Wonderful. I'll update out of live programming hours, and let you know. Is this version stable for a production system?
One other thing with regards to the remote ONAIR viewer: How do you change the icons on the remote viewer? are they hardcoded? the first two I would like to use as PLAY and STOP for MODSTREAM_WATCHER_START and STOP but not found a way to change or label them yet.
phonic
Post by phonic »
Just noticed it's a stable not beta version. Need to check before posting :) I'll update after hours.
The icons cannot be changed, but the names of the ribbon buttons. Just click on the small ribbon caption arrow icon underneath the button group.
