Right clicking on advertising gave Error/Exception
phonic
Post by phonic »
New install. Windows 10 Pro 64bit up to date.
Right clicked on a slot to add new overlay and got the error below:
07/03/2019 11:26:59 [v4.0.5.8]:********** Error/Exception Information **********
Error Source: ProppFrexx ONAIR.Void uKak(System.Object, DevExpress.XtraScheduler.PopupMenuShowingEventArgs)
at ProppFrexx.Advertising.OverlayScheduler.uKak(Object , PopupMenuShowingEventArgs )
at DevExpress.XtraScheduler.SchedulerControl.RaisePopupMenuShowing(PopupMenuShowingEventArgs args)
at DevExpress.XtraScheduler.SchedulerControl.CreatePopupMenu(Point point)
at DevExpress.XtraScheduler.SchedulerControl.OnPopupMenu(Point point)
at DevExpress.XtraScheduler.SchedulerControl.OnWmContextMenu(Int32 lParam)
at DevExpress.XtraScheduler.SchedulerControl.WndProc(Message& m)
********** End **********
phonic
Re: Right clicking on advertising gave Error/Exception
Post by phonic »
The only difference with this installation is that I'm using RealVNC to access to remote studio from home
I've got another one "Unhandled Exception", I've clicked continue on both.
07/03/2019 11:40:23 [v4.0.5.8]:********** Error/Exception Information **********
The 2nd looks like a followup of the first (essentially the same) - still strange.
Can you reproduce this error in some way, as I seems to be unable... I'll still look at it...
Please try the latest v4.0.5.15-Beta (click on 'Check for Beta-Versions...' to update)
phonic
Post by phonic »
It was happening immediately after clicking on any slot in overlay scheduler to add a new overlay, even if I closed it and reopened it.
After I restarted the software, the issue seems to have resolved.
I'll update this thread if it comes back.
