Silencing monitoring volume when PFL is playing.
Felikx
Post by Felikx »
Sorry if this is there is an obvious answer to this question but i have been trying to figure this out for the past 2 hours.
I would like the monitoring volume of the current track, etc... of my headphones to silence so i can hear the PFL better.
Thanks for any help!
Re: Silencing monitoring volume when PFL is playing.
this depends on your mixer setup and how many mixer channels you have defined, what your routing is etc.
But typically you have a dedicated PFL mixer channel. From your default PLAY resp. OUT mixer channel you can then define in your SND2 settings (right-click on the SND button) and select the AutoSnd2 at NoPFL function.
This will only activate the SND function, when no PFL monitoring is active, ie. as soon as you PFL something, this SND routing is deactivated.
