Two tracks playing at the same time after Fix time element
jsonio
Post by jsonio »
I'm using PF for years now and there is still a strange bug happening very rarely : "sometimes" after a fixtime element is played when PF "returns" to the decks to go on with the playlist, two decks start at the same time and two songs are playing simultaneously. It goes on with all the next tracks until the program changes, then everything becomes normal again (one track played at a time).
What do you suggest to try to solve this problem?
I'm using PF 4.0.5.1
Thank you a lot in advance,
Justin
Re: Two tracks playing at the same time after Fix time element
There was an improvement (additional check added) to the v4.0.5.5 - so please try this one!
If it happens again, make sure you have activated the Debug-Logging (see general settings, section More Stuff) and when the issue happends again, please send me created Debug...log file together with the exact time when this happened.
