Rule sets problem
mdegroot
Rule sets problem
Post by mdegroot »
I want to use rules but i'm missing the onair.rulesets file in the proppfrexx folder.
When I now add a rule into the ruleset editor and I close the editor, the rule I added is gone after re-opening the editor.
The tagger is asking for the onair.rulesets file too.
What am I doing wrong?
Kind regards,
Re: Rule sets problem
I cannot reproduce this issue nor have I heard from someone with a similar issue.
What exact version are you using (version number and type of edition)?
If the file "ProppFrexx ONAIR.rulesets" is missing in your ProppFrexx AppUserData folder, this implies that there is a different issue.
Can you please past a screenshot of the rule you are trying to add? Maybe it is specific to your specific rule?
mdegroot
Post by mdegroot »
After doing some more tests, it seems that the rule itself was the problem indeed.
For testing I only added the months July & August as a summer rule, but I didn't adjust the time or days in the rule.
Now I found out that every item has to be filled in, otherwise the rule isn't saved.
Now that my first rule is added correctly, Proppfrexx also made the onair.rulesets file.
My fault.
