Fade in segue editor
Kurt2018
Post by Kurt2018 »
In the segue editor, you can set some volume points. They allows you to fade the music but only by a lineair fade curve or line.
By using a bezier fading curve you can fade more precisely and you need it the most by slow music. Can this built in?
Thanks,
Kurt
Re: Fade in segue editor
The audio engine which I am using currently doesn’t support this. So I’m not sure when and if that will be available.
