Playlist columns
Farbo
Playlist columns
Post by Farbo »
Hi.
If I add a new column to my playlist (for example BPM) how can I save "configuration" so each time I open any playlist then BPM column is there?
Thank you.
Peter
Re: Playlist columns
Please take a look here:
viewtopic.php?f=4&t=2015
Note, that the Playlist Window Layout from now on does NOT save and restore its layout automatically anymore!
So once you defined your desired column layout, make sure to manually save it using the new Miscellaneous Load/Save Layout buttons in the Playlist ribbon.
You can now save 2 different layout versions: a) for manual Playlist and b) for scheduled Playlists.
