Autoupdate Seque Editor
djbony
Post by djbony »
Hi Berndt,
I have problem with autoupdate seque editor in last version PFOA... Doesn't work. Could you look at it? Thank you.
Re: Autoupdate Seque Editor
I cannot reproduce any issue here, but maybe I am testing differently.
Can you describe your exact steps to reproduce.
djbony
Post by djbony »
I have seque editor still open on second monitor. In General Settings/Player Settings - Seque-Editor - Autoupdate - checked.
But it is not renewing...
I have just made a small video to demonstrate, that it is working here as you described it:
https://www.dropbox.com/s/mobffd7x2ij8w ... r.mp4?dl=0
What exact version are you using? What are you doing differently?
djbony
Post by djbony »
I'm doing the same thing as you. I'm using v4.0.4.28.
Can you send a screenshot or video of your playlist - maybe you have 'unplayable' items within your playlist, so that the Segue-Editor is unable to load them as audio tracks?
djbony
Post by djbony »
All tracks are playable. If I click to Refresh button in seque-editor, all works. I try reinstall PFOA and I will see.
djbony
Post by djbony »
After reinstall W10 all works. Thank you.
djbony
Post by djbony »
after reinstall W10 was all ok but if I docked seque editor window, autoupdate stopped working...
Not here - except, the docked segue window is not visible (as this is by design)!
