Use programmable keyboard
Bumperke
Post by Bumperke »
Hi Bernd.
Is it possible to steer and activate the card walls with a programmable keyboard or midi board? And if so,.... how can I fix something?
Will
Re: Use programmable keyboard
Yes of course it is.
You can use the MIDI event mapping to do so.
There is even a tutorial video about it.
Bumperke
Post by Bumperke »
radio42 wrote: 14 Aug 2018 22:11 Yes of course it is.
Thxs
Bumperke
Post by Bumperke »
In that video, at the beginning you also refer to ipad control, how does that work? And can i bring the RVT Commands to the hotkeys aswell?
Like Ctrl-F11 for opening etc?
Will
You can also use your IPad/iPhone or other tablet supporting the Open Sound Control protocol, as explained here:
viewtopic.php?f=9&t=23&p=52
