Crash in Onair
Ahmed Saied
Crash in Onair
Post by Ahmed Saied »
Hi , I have an issue in events logs can describe the issue code what it means ! Log Name:
Application Source: Application Error
Date: 8/4/2018 12:25:20 PM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Description:
Faulting application name: ProppFrexx ONAIR.exe, version: 3.0.15.21, time stamp: 0x562dfb5d
Faulting module name: bass_mpc.dll, version: 2.4.1.1, time stamp: 0x4ec122e3
Exception code: 0xc0000005
Fault offset: 0x00002b9e
Faulting process id: 0x384
Faulting application start time: 0x01d427d926284d4c
Faulting application path: C:\Program Files (x86)\radio42\ProppFrexx ONAIR\3.0\ProppFrexx ONAIR.exe
Faulting module path: C:\Program Files (x86)\radio42\ProppFrexx ONAIR\3.0\AddOns\bass_mpc.dll
Report Id: b01ddba1-97d0-11e8-bca9-902b34f8dac0
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2018-08-04T10:25:20.000000000Z" />
<EventRecordID>15641</EventRecordID>
<Channel>Application</Channel>
<Security />
</System>
<EventData>
<Data>ProppFrexx ONAIR.exe</Data>
<Data>3.0.15.21</Data>
<Data>562dfb5d</Data>
<Data>bass_mpc.dll</Data>
<Data>2.4.1.1</Data>
<Data>4ec122e3</Data>
<Data>c0000005</Data>
<Data>00002b9e</Data>
<Data>384</Data>
<Data>01d427d926284d4c</Data>
<Data>C:\Program Files (x86)\radio42\ProppFrexx ONAIR\3.0\ProppFrexx ONAIR.exe</Data>
<Data>C:\Program Files (x86)\radio42\ProppFrexx ONAIR\3.0\AddOns\bass_mpc.dll</Data>
<Data>b01ddba1-97d0-11e8-bca9-902b34f8dac0</Data>
</EventData>
</Event>
Can you give me solution for this problem !
Re: Crash in Onair
The v3 is out of support since almost 3 years and has reached its end of live.
As such, there is no active support anymore.
However, the crash looks like it is coming from a faulty MPC audio file.
