[PROBLEM SOLVED] Get datas from proppfrex with php
maniacshu
Post by maniacshu »
Hi everybody!
I have a little problem with proppfrex on air scripting. We want to send the song meta datas with EXEC_SEND_HTTP_GET command. If we are press Test button it works correctly. In that case, if we try on a real playlis we get nothing.
Our script (OnTrackPlay):
EXEC_SEND_HTTP_GET http://localhost/radiodata.php?title=${title}
Our php code:
<?php
file_put_contents("data.txt",print_r($_GET,true));
Thanks for your help :)
Two parameter in two lines, generate listing bug, and the writed file going corrupted.
Not use any parameter line, same information! Code is working, problem solved!
Radio is not an activity, rather a sense of life.
Re: [PROBLEM SOLVED] Get datas from proppfrex with php
Glad you solved it.
