Error
andre
Error
Post by andre »
Bernd, after the last update i get an error when i open the tag editor.
I think the mood tags are the problem
3-6-2018 09:03:07 [v4.0.4.25]:********** Error/Exception Information **********
Error Message: Can't transform the 'Upbeat' part of 'Upbeat' EditValue in Tokens
Error Source: DevExpress.XtraEditors.v18.1.Void RaiseMapperPanic(System.String, System.String)
at DevExpress.XtraEditors.TokenEditValueMapperBase.RaiseMapperPanic(String key, String editValue)
at DevExpress.XtraEditors.TokenEditStringEditValueMapper.DoGetTokens(RepositoryItemTokenEdit properties, Object editValue)
at DevExpress.XtraEditors.TokenEditValueMapperBase.GetTokens(RepositoryItemTokenEdit properties, Object editValue)
at DevExpress.XtraEditors.Repository.RepositoryItemTokenEdit.DoUpdateSelectedItems(Object editValue)
at DevExpress.XtraEditors.TokenEdit.UpdateSelectedItems()
at DevExpress.XtraEditors.TokenEdit.OnEditValueChanged()
at DevExpress.XtraEditors.BaseEdit.OnEditValueChanging(ChangingEventArgs e)
at ProppFrexx.TAGEditor.vmIQ(MediaEntry , Boolean )
at ProppFrexx.TAGEditor..ctor(MediaEntry track, Boolean noSave)
at ProppFrexx.BrowserTree.TaHs(TreeListNode )
at ProppFrexx.BrowserTree.TaHU(Object , ItemClickEventArgs )
at DevExpress.XtraBars.BarItem.OnClick(BarItemLink link)
at DevExpress.XtraBars.BarButtonItem.OnClick(BarItemLink link)
at DevExpress.XtraBars.BarItemLink.OnLinkClick()
at DevExpress.XtraBars.BarButtonItemLink.OnLinkAction(BarLinkAction action, Object actionArgs)
at DevExpress.XtraBars.ViewInfo.BarSelectionInfo.ClickLink(BarItemLink link)
at DevExpress.XtraBars.ViewInfo.BarSelectionInfo.UnPressLink(BarItemLink link)
at DevExpress.XtraBars.Controls.CustomLinksControl.OnMouseUp(MouseEventArgs e)
at DevExpress.XtraBars.Controls.CustomControl.WndProc(Message& msg)
********** End **********
This happends when i add the mood tag.
Greetings, Andre.
Re: Error
I’ll take a look!
Re: Error
Fixed in v4.0.4.26.
andre
Re: Error
Post by andre »
It's fine now.
Thanks.
