Voice Tracking problem with current programs
Ahmed Saied
Post by Ahmed Saied »
Hi ,
I have case related to Voice Tracking , I want to record voice tracking with 3 PlaceHolders , each one have 1 min , but in the same time i have playlist with base script musics pausing and waiting for (other playlist) " no overlay option "and (other playlist) with 20 mins only "overlay cue option playing" ,so i want to put the place holders in base script playlist and record all of them to play after closing the other playlist and i want to make sure from playling all Overlays slots every 30 mins from 8:00AM >>23:30 AM .
Thanks ,
Re: Voice Tracking problem with current programs
I am afraid I don't fully understand your 'problem' - can you please try to explain this in a bit more detail.
Note, that you can define a placeholders in your base script by using the "Placeholder" mode as a dedicated script-line. These placeholders are anyhow just indicators for the manual voice tracking.
To define within your based script where to play overlays, you can use the "Embedded Container" mode - you then select the overlay to play here.
But from your mail it sounds like you might have other issues.
Ahmed Saied
This is actual problem really and thanks for you ,
Can i ask you another question related to Program that has 30 Episodes , i want to take 1 episode sequential based on script but i want to make sure that's playing every day like this EP 1 , EP 2 , EP 3 , .... etc how make this and avoid the repeated episode ?
You might create a playlist based media lib (ie. first create a new and empty playlist, add your files in the right order, save that playlist under whatever name). Then you use this playlist file as a playlist based media library. Make sure to specify a History Count for that media lib and set it to -1 !
In the script you now select the Sequential mode and specify your media lib as the entry. That’s it.
Ahmed Saied
Its fine ,but how to make sure to take 1 episode only ! for example the playing playlist of program is 20 mins soft with overlay , one cycle
Ahmed Saied
and now i make script and playlist the same you were told me before , but take 1 episode in 1 day and other day don't take any Episodes ! i don't know what are happen !
Then you need me to show all your setting, scripts etc. as you somewhere probably made a mistake.
