contains Embedded Overlay Container means?
Bumperke
Post by Bumperke »
Hi Bernd, how can i clear/fix this?
2-3-2018 13:58:59: WARNING: Overlay 'NEWS 2018@2018-03-02T14:00:00'
was suppressed (Future Playlist 'Admin_Playlist RVT Template [14.00 tot 15.00] @ 2-3-2018 14:00:00@2018-03-02T14:00:00' contains Embedded Overlay Container).
2-3-2018 14:59:01: WARNING: Overlay 'NEWS 2018@2018-03-02T15:00:00'
was suppressed (Playlist 'Admin_Playlist RVT Template [14.00 tot 15.00] @ 2-3-2018 14:00:00' contains Embedded Overlay Container).
Re: contains Embedded Overlay Container means?
I assume you know what an embedded overlay container is.
It is for example created when you resolve an overlay to a playlist item, eg. this is happening by default when using the Playlist Template Wizard to pre-create playlists in advance.
Whenever a currently running playlist contains such a embedded overlay contained, the regular scheduled overlay will be suppressed - this to ensure, that Overlays are not played twice!
So there is not much to fix.
Except, that you should not use embedded overlay containers when you want to let them play via the overlay scheduler.
I actually don’t know your system and setup, so do t know how you have used and created embedd d overlay containers, but I guess you’ll know this best.
Bumperke
Post by Bumperke »
radio42 wrote: 02 Mar 2018 15:10 I assume you know what an embedded overlay container is.
Oké, but how do i get the news into the schedular? Do i need to enable of disable something?
This is the Professional version BTW.
I don’t understand your question?
What has this to do with the News?
And what scheduler are you talking about? The program or overlay?
However, you need to either put ALL your Overlay scheduler Entries into the playlist as embedded overlay containers or None!
It is not possible to schedule one half as embedded containers and others via the overlay scheduler.
The News Management is only enabled with the Enterprise Edition!
Bumperke
Post by Bumperke »
radio42 wrote: 02 Mar 2018 15:44 I don’t understand your question?
Oké, now this makes sence. This is not Enterprise
Thxs
