barix instreamer
andrus2000
barix instreamer
Post by andrus2000 »
How to send artist-song to barix instreamer?
Send metadata please use the E=command. After the "E" parameter, you should see the song´s title. The command is extremely key sensitive. The correct syntax is: http://<ip-instreamer>/rc.cgi?E=StreamTitle='Title';
But not working this
Re: barix instreamer
You can probably use the EXEC_SEND_HTTP_GET command to do so, e.g. something like this:
EXEC_SEND_HTTP_GET http://127.0.0.1/rc.cgi?E=StreamTitle='${trackname}';
Use this command in the Streaming.OnSongTitleChanged event (see the general settings, section Events/Commands)
andrus2000
Thank you, it works well. But is there an option to get rid of advertising?
Advertising where - (I don't know what you are talking about) - guess this does not come from ProppFrexx?!
andrus2000
all good, i find it all what i needed :) thank You!
