segue editor zoom issue
moogwill
Post by moogwill »
something goes wrong with segue editor.
And i can't find how to solve that:
When opened with default selected, only a small part of the selected song(s) is/are available. using bottom's window arrows left and rightI can only move inside this small section.
If I want to see the next track or more I can zoom out but it's impossible to center the zoom on other part of the screen. zoom in always takes me back to the original center section.
It makes very difficult any mix edition.
Re: segue editor zoom issue
I am not sure what you mean by "default selected", but the segue editor might open with either 2 or 3 tracks being displayed (depending on their total length).
The small arrow key at the bottom don't move the view port, but find adjusts the position of the currently selected track.
The change the view port use the scroll-bar.
Please describe with a bit more detail what you think is a bug - as I cannot experience any!
Maybe a screen-shot or small video illustrating your issue might help - else I am not really sure what exactly you mean.
Also try using the Mouse-Wheel:
- normal scroll: moves the view port
- holding CTRL: changes the zoom level
moogwill
Post by moogwill »
http://www.easymedias.com/pfissue/Enreg ... 44_373.mp4
as you can see i wish to zoom the mix section but it's impossible...
This indeed looks totally strange!
As I am unfortunately unable to reproduce that here, can you please send me (eg. via a PM or mail):
- the playlist file (.pfp file) of your example
- the 3 files audio files you have selected for the segue editor (which is the one on which you right-clicked to start the Segue Editor plus the 2 subsequent)
- your "ProppFrexx ONAIR.config" file (can be found in the PF AppDataUser folder)
moogwill
Post by moogwill »
Problem solved by itself.. without doing anything.
Those kind of issues are the best ;-)
Still funky... but I am glad it is fixed.
