Special mixing settings
Michel67
Post by Michel67 »
busy with settings fading:
“Limit Seque” what does this setting do?
where can I find some explanation about fader settings?
Re: Special mixing settings
You can click on the '?' icon at the top right of each dialog to get a detailed help about all options/settings available.
Limit Segue:
If checked the mixing/segue time will be limited by the following options - else mixing is carried out independently per track.
Note: These limits are ONLY used during AutoPlay within the DJ Players of a Playlist and ONLY in case the current track's cue-points have been automatically calculated (ACPD took place) and ONLY in case the previous track doesn't already contain a manual Next cue-point yet (except the Force option below is selected)!
Max. Overlap dB: Limits the segue time for a previous track by calculating a position at the start of this track. The previous track is allowed to overlap up to this position.
Min. Segue: Defines a minimum allowed mixing duration. If the position calculated by the 'Max. Overlap' option results in a shorter segue, this minimum value is used instead.
Max. Segue: Defines a maximum allowed mixing duration. If the position calculated by the 'Max. Overlap' option results in a longer segue, this maximum value is used instead.
Use Ramp1 as max. Segue: If checked, the Ramp1 cue-point will in addition limit the max. mixing time.
In any case, the limit options will adjust the Next cue-point of the previous track once a track is loaded to a DJ Player!/Total Mix-Time = CueOut - Next
Michel67
Post by Michel67 »
thank you for the clear explanation, I'm going to work with it.
