Fixed playlist column width
Is it possible to have the same fields and column width for all the playlists I open or create ?
I think that beta 4.0.4.2 does not save column widths.
By the way I find a little difficult to adjust the width of each column because each time I resize one column all the others resize too. For example even when I resize the 4th column even a pixel, the 1st column resizes too.
Re: Fixed playlist column width
You are right. I had enabled "Auto width" in playlist settings. I disabled it.
However I manualy adjust the width of each column until the scroll bar below the playlist disappears. But when I open the playlist the column widths are not as before and the scrollbar below arrears again.
A new v4.0.4.3-beta is available which fixes this issue!
True, when AutoWidth is disabled it will indeed not restore correctly. I already fixed it, so it will be included in the next release!
The playlist column location and width is saved whenever you clise a Playlist.
The next Playlist opened will restore these settings.
The way how the Playlist is resized is defined by a Windows standard and I have no influence on this behavior.
However by default the AutoWidth option is enabled, meaning all visible columns will occupy the total available width of the playlist. As such it is totally normal, that when you increase one column, that another must be decreased.
Else you can disable this option in the general playlist settings.
I 've tried v4.0.4.3-beta and it's not fixed
I just tried it here and it is working. I have uploaded a video to show how I tested it:
https://www.dropbox.com/s/9tftntugp0s33 ... 4.mp4?dl=0
I am doing EXACTLY what you do but I have not the same results.
I 'll try to create a screencast to show you
you have pm
Very strange. Can you please try to delete your file called "ProppFrexx ONAIR.Playlist.layout" (contained in your ProppFrexx AppUserData folder) and try again.
Else, there is also a new v4.0.4.4-beta, don't know, if that makes any difference, as I didn't change anything in that respect, but it uses a lightly newer UI lib version.
