user commands
moogwill
user commands
Post by moogwill »
hi Bernd, is there a way to configure user commands switches? change text and/or icon?
Re: user commands
Yes, sure.
Select the 'Tools' ribbon tab and click on the small arrow icon below the 'User Commands' group.
This invokes the 'User Control Command' dialog.
When you now select the 'Command(s)' cell of a related user command, you'll see a 'Name' button at the end - click it to change the name and icon of that user command.
