Full Reset PF OnAir
GuntherM
Full Reset PF OnAir
Post by GuntherM »
I'm new, and I'm wondering if there is a way, to reset the playout system back to 0?
Like factory settings? Or do I have to reïnstall the complete software?
Thanks in advance,
GuntherM
City Radio Flanders
Re: Full Reset PF OnAir
A reinstall would not even remove/reset anything.
To completely remove all options and settings close PF and then delete the entire ProppFrexx AppUserData folder.
If you have created any other folders, eg. an Advert Storage Path, delete these as well.
