Remote Voicetrack Different Clients
marinohb
Post by marinohb »
I want to have different clients with different audio compression (One has very slow internet and another one has a super fast network). Is that possible?
Thanks
Re: Remote Voicetrack Different Clients
No. There is only one compression mode for all clients.
You can only define to not use the compression with certain clients, eg. if they are on the same LAN.
marinohb
Post by marinohb »
Okay. Another question, Is possible to download just the first minute of a song in order to download the playlist faster?
No. But you can select the ‘Playlist Only’ option.
This will at first only download the playlist only (as the name suggests).
The audio tracks can/will then be download on demand when needed, eg. when you start a Voice Tracking session between 2 tracks.
