Fade
Frans
Fade
Post by Frans »
Since the latest version (V.77) there is a problem with the fading between two tracks. When i use the segue editor, it's possible to ad volume points (as usual) but the volume doesn't change. V.76 doesn't have this problem.
Can you please look into it.
Thanks.
Greetings,
Frans
Re: Fade
True!
Unfortunately, there was a build bug in the .77, which prevented the Volume-Points (in any) to work correctly.
A new v4.0.3.78-update was therefore needed.
