items double plaing and overlays block zero lenght
vytaut11
Post by vytaut11 »
Hi!
After upgrading ProppFrexx yesterday there is two bugs
1. Draging and dropping item from search window to player it will be played 2 times (repeated)
2. Overlays block lengt are with zero lenght
RadioMaxDK
Re: items double plaing and overlays block zero lenght
Post by RadioMaxDK »
Are you running the latest 4.0.3.76? It was released Saturday Afternoon
Yes, make sure to run the latest .76.
In the previous .75 there was a bug introduced.
vytaut11
Post by vytaut11 »
Hi, after upgrading to .....76 overlays block zero lenght problem is fixed.
But still there is problem with items manually dropped to playlist from search. Item will be repeated (it will played twice)
Please make a video to demonstrate the 'repeat item when dropped from search', as I canot reproduce that in any form here.
Thanks,
Bernd
Please try the latest v4.0.3.77-update.
vytaut11
Post by vytaut11 »
Hi!
After upgrade to v. 4.0.3.77 is double playing problem fixed. Thanx!
