Mix Delay-Time and TUS
Bo98A
Post by Bo98A »
Is it just me or does "Mix Delay-Time" (under "Manual Fading") not seem to have any effect on the fade-out by a TimeUpdateSync?
Right now the next track seems to start after the fade completes, while it would be better if it was during the fade.
"Fade-Out Length" under the same section works fine.
Re: Mix Delay-Time and TUS
Yes, currently a TimeUpdateSync doesn't not use any Mix DelayTime, resp. it uses a fixed delay time of 90% of the Fade Out Time.
I might look into it to leverage the media entry type specific (resp. the default manual) Fade Out and Mix Delay Time in the next release.
I provided a v4.0.3.67-update, which now also honors the manual Mix-Delay Time with TimeUpdateSyncs.
Bo98A
Post by Bo98A »
Thank you, I will try it out.
