v4.0.3.61-stable
v4.0.3.61-stable
Version 4.0.3.61 is out!
What's New?
  • History to Find Window added
  • new Ember+ lib verison
  • Allow private OpenWeatherMap API key
  • Scriptline mode TimeUpdateSync bug-fix
  • Database Media Library get track bug-fix
  • FTE scheduling with RemoteVoiceTracking bug-fix
  • Scheduled TimeUpdateSync bug-fix
  • DJ Player FadeOut bug-fix
  • Other smaller bug-fixes
  • stable
Mainly another roll-up and bug-fix release.
The main new feature is the history within the Find window. You can now use the ALT+Backspace key combo to go back to your previous search (if that existed). Another new key shortcut in the find window is CTRL+P which toggles back to the current playlist window.
So far we used an internal free OpenWeatherMap API key. This limited the accuracy and the refresh interval to 3 hours.
When you right-click on the Weather symbol (at the top right), the related context menu now contains a new “Set Private API Key…”
Use this to provide your own and private OpenWeatherMap API key, which might provide greater accuracy and allows more frequent updates.
Derek
Re: v4.0.3.61-stable
Post by Derek »
Thank you for the update Bernd. I use the private OpenWeatherMap API key and works perfect :)
