Slow browsing explorer window
ferryvh
Post by ferryvh »
Hi bernd,
I'm having some problems with proppfrex versions v4.0.3.43/44/45
Whem i'm scrolling through large folders in the browser window, it looks like the system is about to crash.
Everything seems to hang for a few seconds. The PFL player, the Players and the browsing window stands stil.
After this, the scrolling through the browsing window stutter.
The latest official release v36 works without any problems.
Re: Slow browsing explorer window
Thanks for your video.
Actually I cannot really see anything, which justifies the assumption, that "...the system looks like the system is about to crash."
What happens though, is that when you do extensive scrolling, that the UI freezes shortly (for about 1 or max 2 sec.) while the explorer tree is refreshing.
I can only assume, that this might be due to the new version of the UI lib whch I am using - but as said, I cannot reproduce that here.
However, I tried to adjust a few things according to the new UI lib verison and provided a new v4.0.3.47-beta (use "Check for Beta-Versions..." to update). Maybe it helped already...
That is actually strange as nothing was changed there in the explorer.
What is a large folder?
Have you may be changed your TAG reading settings or the sorting of the explorer window?
And does it become faster after some time, e.g. after all files have been read in?
Just tested it here with a folder containing 6.000 tracks and can not reproduce the issue.
Scrolling is as fast as with a folder containing only 100 tracks.
Maybe you can provide a small video which shows your settings and demos the issues...
