Error Message
Error Message
Updated this morning to v4.0.3.43 but after a while, get an error, do not know this PF or WIN10 is related
29-6-2017 08:15:21 [v4.0.3.43]:********** Error/Exception Information **********
Error Source: DevExpress.XtraBars.v17.1.Boolean get_Enabled()
at DevExpress.XtraBars.BarItemLink.get_Enabled()
at DevExpress.XtraBars.Ribbon.Handler.BaseRibbonHandler.CanPressItem(RibbonHitInfo hitInfo)
at DevExpress.XtraBars.Ribbon.Handler.BaseRibbonHandler.OnMouseDown(DXMouseEventArgs e)
at DevExpress.XtraBars.Ribbon.RibbonStatusBar.OnMouseDown(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
at DevExpress.XtraBars.Ribbon.RibbonStatusBar.WndProc(Message& m)
********** End **********
Re: Error Message
Yes, I remember that. It was the 'open' button.
- PF.jpg (12.35 KiB) Viewed 8770 times
Re: Error Message
So please try the above and see, if this already helps... here all works as expected.
Unfortunately I cannot reproduce this issue...
Re: Error Message
Done and so far it is going well
Re: Error Message
OK!
Re: Error Message
Hard to say. Do you remember what button you pressed in the ribbon.
Actually I cannot reproduce the issue here.
Maybe you can close PF and then try to delete the file called "ProppFrexx ONAIR.ribbon" and "ProppFrexx ONAIR.toolbar" and then restart PF.
(the files are located in the %AppData%\radio42\ProppFrexx ONAIR\4.0 folder)
