Placeholder with powergold
This forum is unmoderated!
marinohb
Post by marinohb »
How I can place a placeholder with Powergold? Is there a command for that?
Thanks
Re: Placeholder with powergold
Within the Powergold export log file, the 'EventType' column should be set to "BRK" and the 'Filename' column should be left empty.
This is how you define a Placeholder within the scheduler export log file.
But I don't how how to define/set this within Powergold itself, guess this is a question to their support forum?
