start/stop streaming
mikedude
Post by mikedude »
Is there a way to start and stop streaming manually?
I only can get it to start by selecting "connect at startup" and restart ProppFrexx.
Can't find it in the manual.
thanks
Re: start/stop streaming
Sure you can.
Simply right-click in the Network Monitor window panel on the desired streaming server entry and select 'Start Server' resp. 'Stop Server'.
There are even related control-commands available (see the Appendix of the User Manual) in order to start/stop the streaming servers via a remote control command.
