Internet settings changed
Bumperke
Post by Bumperke »
Hi Bernd.
The PF playout did have another IP adress and the router is also changed. How can we set the settings for local and distance again. No one is able to voicetrack anymore. Can you help us?
The ip was: tcpex://192.168.0.111:9042/ProppFrexxRemoteService
The new ip number of this computer is 213.125.2.2
What do we do to fix that problem?
Will
Re: Internet settings changed
I am not sure what you mean. ProppFrexx is not responsible for your internet setup nor can ProppFrexx change anything in your network.
So you must have changed something.
I am afraid, that I am not your network administrator.
However, the 192.... address seems to be your local IP address, which is only reachable within your local network.
The 213... address however seems to be your external IP address.
So if you want to reach a local PC from 'outside', you must configure your Router to forward the connection. This is called Port Forwarding. In your Router configure a forwarding of the port 9042 to your local IP 192...
Bumperke
Post by Bumperke »
The play out is still working but the ip from that computer changed. I get what you saying, but internally we are not able to connect. Same network. To be simple, if the IP from the computer changes, the tcpex address has to change as well?
Yes of course.
You need to specify the IP address of that PC. So if that changed, you need to specify the new IP address.
Bumperke
Post by Bumperke »
radio42 wrote: 14 Apr 2017 22:01 Yes of course.
And how do I chance it and where? Perhaps stupid question but i where do I put the new IPs?
??? I don't understand what you are trying to say.
You said that the IP address of your PC in your network changed.
So in order to connect to this PC from another PC you need to specify the new IP address in the tcpex URL.
Bumperke
Post by Bumperke »
radio42 wrote: 14 Apr 2017 22:12 ??? I don't understand what you are trying to say.
And that's the answer, but where? I presume in the menu, but where? Can you show me how to do that?
Thxs.
Will
When you start the remote Voice Tracking session on the client you need to enter the tcpex URL. That's where you need to specify the new IP of the server PC.
Just to be sure you understand.
ProppFrexx does not specify an IP address of a PC.
Your network router assigns an IP address to the PC.
So if you try to change the IP address of your PC, then you can only do this in your network router.
Bumperke
Post by Bumperke »
radio42 wrote: 14 Apr 2017 22:28 Just to be sure you understand.
Everything is oké now.
