Temperature Announcement
vsolivie
Post by vsolivie »
Hello good morning we are trying to make the temperature and relative humidity of the air work and we are doing so, but it does not work
1º attempt LoadTrack, C:\weather\${weathercurrenttemperature}.mp3, Count=1, Options=SuppressAddHistory, SuppressHistoryCheck
Mp3s are in this format
0.0
1.0
2.0.
3.0
10.0
11.0
12.0
etc... etc...
How should I proceed to make this work?
Re: Temperature Announcement
Ahh, sorry, but with the v3 it is not working anymore!
So why do you use v3 ???
As you have not purchased a license yet, you must use the Demo Version anyhow!
So why don't you use the official and latest v4 Demo to test it?!
Maybe you first use this command to see, what exactly ${weathercurrenttemperature} resolves to in your case:
SHOW_ALERT_WINDOW Weather Temperature|${weathercurrenttemperature}
In my case this reveals, that the temperature is given as a whole number, e.g. 10.
If so, you might need to name your files:
1.mp3
2.mp3
10.mp3
(P.S: Please submit these sort of posts in the future into the "Question & Answers" topic.)
vsolivie
Post by vsolivie »
Forgive me for my ignorance but I do not understand is this the code?
No of course NOT!
You can just use that control-command (e.g. in a User Command) to test what the macro ${weathercurrenttemperature} does effectively returns.
You assumed, that it would deliver a number with a decimal point, but I assume, it only delivers a single integer number.
Thus you need to correct your mp3 file names!
Your "LoadTrack" entry should still be:
vsolivie
Post by vsolivie »
Hello good night what could I be doing wrong?
Rename the files as you told me but something is still wrong
Where do you think I'm wrong? :ugeek:
What FileName is scheduled when you run the script in a playlist?
Have you checked this?
And why did you specify an 'Archive' playlist? This can be removed I guess, as well as the 'Reload' option.
vsolivie
Post by vsolivie »
So it is not necessary to mark nor reloading nor the archive path? :ugeek:
No.
So did you test your script inside a playlist (just right-click into a playlist and select 'Add -> 1 random Track -> Script -> yourscriptname)...
And what filename was resolved to it?!
vsolivie
Post by vsolivie »
Hi, good afternoon, I may not have been very clear in my question, but what I need is to inform the temperature and the reactive humidity of the air automatically, for example I want to reproduce real weather conditions :oops: :mrgreen:
