v4.0.3.20-stable
v4.0.3.20-stable
Version 4.0.3.20 is out!
What's New?
  • LineIn Feed Follow DJ Player option added
  • SegueEditor UAC Close button bug-fix
  • 32bit version BASS_NFX bug-fix
  • Other smaller bug-fixes
  • stable
Basically a bug-fix release, mainly for the 32bit version, as the last build contained a build error to prevent ProppFrexx 32-bit to start.
Copper007
Re: v4.0.3.20-stable
Post by Copper007 »
After updating I get this:
9-4-2017 17:59:31 [v4.0.3.20]:********** Error/Exception Information **********
Error Message: Could not load file or assembly 'BASS_NFX, Version=2.4.8.4, Culture=neutral, PublicKeyToken=bfe0788e80391218' or one of its dependencies. Strong name validation failed. (Exception from HRESULT: 0x8013141A)
Error Type: System.IO.FileLoadException
Error Source: Bass.Net.Int32 BASS_NFX_GetVersion()
Inner Exception: Strong name validation failed. (Exception from HRESULT: 0x8013141A)
at Un4seen.Bass.AddOn.Nfx.BassNfx.BASS_NFX_GetVersion()
at Cf.Gm.DOCH()
at ProppFrexx.ProppFrexx_ONAIR.OimQ(Object , EventArgs )
Error Message: Strong name validation failed. (Exception from HRESULT: 0x8013141A)
Error Type: System.Security.SecurityException
Error Source: .
at ProppFrexx.ErrorDialog..ctor(Exception e, Boolean getFullInfo)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at DevExpress.XtraEditors.XtraForm.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.NativeWindow.DefWndProc(Message& m)
at DevExpress.Utils.Taskbar.Core.FilterWindow.WndProc(Message& m)
at System.Windows.Forms.SafeNativeMethods.ShowWindow(HandleRef hWnd, Int32 nCmdShow)
at System.Windows.Forms.Control.SetVisibleCore(Boolean value)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at DevExpress.XtraEditors.XtraForm.SetVisibleCore(Boolean value)
at DevExpress.XtraBars.Ribbon.RibbonForm.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at System.Windows.Forms.Application.Run(Form mainForm)
at c7.Ho.Oi02(String[] )
********** End **********
We are on RDJ backup now... fresh install doesn't help....
Erik
Then please try to install the regular setup (download from our web-site) as something must have gone wrong with the update. It already worked for many others.
