Silence between 02 and 04 A.M. since summertime
rvtienhoven
Post by rvtienhoven »
Since the transition from wintertime to sumetime last sunday, every day between 02:00 and 04:00 AM, there is nothing played. In the program scheduler is nothing changed. I send you the overlay and scheduler log and my calendar.
Regards,
Remi
rvtienhoven
Re: Silence between 02 and 04 A.M. since summertime
We use now version 4.0.1.52.
If i look in the programscheduler, I see that there are fixed programs with scripts between 02:00 and 03:00 and between 03:00 and 04:00. This programs have a occurring set on daily. My scheduler is set to Isolated. The reason of this is that I want to know when there is a gap in my program scheduler.
I have send you also my program scheduler file. Is there something strange in there? I've just restarted Proppfrexx. maybe that will help.
Regards
Remi
Have you set your scheduler to Continuous or Isolated mode (see general setting, section Scripts/Scheduler - checkbox 'Continuous Mode')?
Make sure, it is set to Continuous (the default, checkbox checked).
Form the log files you have send me, it looks, like you have changed your scheduler on the 26th (to schedule an extra program between 1:00 and 3:00 am)? Which was actually not needed, as the scheduler handles the DST shift automatically.
And that this exception you scheduled is still running until today.
These are the log entries:
27-3-2017 0:59:44: Program:Muziek in de Nacht (Muziek in de nacht 15), Start:27-3-2017 1:00:00, End:27-3-2017 2:00:00, Started:True
27-3-2017 3:59:45: Program:Muziek in de Nacht (Muziek in de nacht 15), Start:27-3-2017 4:00:00, End:27-3-2017 5:00:00, Started:True
So there is a program started at 1:00 and then the next at 4:00; but the 1st one runs only 1 hour; i.e. if set to isolated mode, there would be no program running between 2:00 and 4:00am.
What exact version are you using?
No, but I can only look to the scheduler with the recent version.
As you are using a quite old v4, I suggest you should definitely first go to the latest version (v4.0.3.11 or higher).
rvtienhoven
After a restart of Proppfrexx, everything works fine. Can I update directly from V4.0.1.52 to the latest version?
Yes, but the latest version requires the .Net Framework v4.6.2, which might be installed during the update.
I suggest you install it prior to the update to make sure all runs smoothly:
https://www.microsoft.com/download/deta ... x?id=53345
