MusicMaster scheduler import format template
marinohb
Post by marinohb »
Hello.
I cant find the MusicMaster Import Template listed on the v4.0.0.13 update.
Am I on the right place?
Re: MusicMaster scheduler import format template
The v4.0.0.13 is a very old version ;-)
There was even a bug in the MusicMaster import back since then which was corrected in v4.0.0.16 ... so please try the most recent version, which is currently:
- Official: v4.0.3.11
- Beta: v4.0.3.13
marinohb
Post by marinohb »
Im using the Beta version v4.0.3.13 and still doesn't appears
That's strange.
Please find attached the needed file - unzip it to your ProppFrexx ONAIR AppUserData folder.
E.g. "C:\Users\yourname\AppData\Roaming\radio42\ProppFrexx ONAIR\4.0"
and overwrite the existing file called "ProppFrexx ONAIR.importformats".
ProppFrexx ONAIR.zip
(3.45 KiB) Downloaded 462 times
A new v4.0.3.14-beta now also includes the above/full .importformats file.
marinohb
Post by marinohb »
Thanks!
