talkuser problem
danurjuma
talkuser problem
Post by danurjuma »
I have a problem with talluser .in when leaving outro starts simultaneously playlist and mix TOGETHER.How solve the problem?Setting propprexx took my time and get out of the demo period and to present to the heads and pressed me so..
Re: talkuser problem
I am afraid I do not understand your issue. Can you explain what exactly you mean?!
And what should play together?!
TalkUser is a wrapper, which also might activate TalkOver, which basically attenuates certain (defined) mixer channels.
But TalkUser by default does NOT play anything - so what should play together?, except you have set a Soundbed... but I don't know any of your TalkUser settings.
However, if you have set a Soundbed to start with your TalkUser action, yes, that might play together with you playlist (if you did not pause it in your settings - see the 'Stop Playlist (AutoPlay) and ...' setting, e.g. make sure to set this to either 'Pause the current playing Track' or 'Ejest the current playing Track').
danurjuma
Post by danurjuma »
When I use talkuser with the intro and outro to the bed out of talkuser track from the playlist starts simultaneously with the outro
danurjuma
Post by danurjuma »
How do I set the PLS_CURRENT_AUTOPLAY_ON to start with a delay of 8 sec
The "MixOut-Time" of the TalkUser Settings delays the start of the playback accordingly.
Have you tried this setting?
