How to start players fader with a midi controller ?
Yvetiboom
Post by Yvetiboom »
How to configure ProppFrexx fader start the ABCD players with a BCF2000?
meisterpropper
Re: How to start players fader with a midi controller ?
Post by meisterpropper »
Perhaps you can set a sticky F.A.Q. for Questions and Answers with all such topics?
Yvetiboom
Post by Yvetiboom »
Sorry my English is very bad but thank you ;-)
Parcontre je n'arrive pas à comprendre ou l'on parle de starter les players directement au fader car mon probleme c'est que si je repasse au point cle "=" pour eteindre mon fader la piste suivante se lance ? Alors que je voudrais quel passe en Load Next en Fader 0.
Traduction du Francais en Anglais avec Google Traduction.
Parcontre I can not understand or we talk about the players directly to the starter fader because my problem is that if I go back to the key point "=" to put out my next track fader starts? So what I would like to pass on Load Next Fader 0.
Yvetiboom
Post by Yvetiboom »
My problem it is because when I puts on my fader a command(order) "=" in a value to throw(launch) the reader the sound dashes but if the sound finishes and what the following one takes care, by lowering(dimming) the fader to put out(switch off) my slice(edge) I am to oblige of ironed by the point "=" which is going to throw(launch) the reader.
- well a simpler version
My fader and parametrized to throw(launch) the reading on a value "=".
The sound dashes to there everything is OK
But if my fader and always at the top and what the sound has stops being played by lowering(dimming) him(it) I go back by equal who boosts(sends a reminder) him(it) to me.
But I wants to cross(spend) just more by "=" how to make or he(it) in you it he(it) a technique.
- even simpler version
1) Fader puts out(switches off) - reader loaded with
2) Fader rise (Command(Order) "=" activates Player ")
3) The player plays
4) The sound finishes
5) Him(it) according to sound takes care
5) I lower(dim) the fader I go back by the value "=" of start
6) The sound dashes
I want ironed by 0 every time to throw(launch) the start
How can it be done?
I hope
Please take a look to the post:
viewtopic.php?f=9&t=22
I am also sorry, but I am affraid I do not understand your question.
are you looking for a particulat control-command?
Or can try to explain your exact issue?
Yvetiboom
Post by Yvetiboom »
Sayais I managed to solve my problem thank you and sorry
