Comments on the Log
marinohb
Comments on the Log
Post by marinohb »
Can I add comments on a playlist? I would like to add instructions to the jocks and they can see them on the screen.
Re: Comments on the Log
Yes, you can add so called Placeholders to playlists. Or you can even add a word document, PDF, text or HTML or open document file. When die the content can be displayed.
And you can add to each track in the TAG Editor either a Comment or even a ModeratorText.
I hope this is enough possibilities ;-)
marinohb
Post by marinohb »
Ok.
Can I add placeholder from MusicMaster ?
I am not sure if MusicMaster supports this concept?
I guess the current MusicMaster file interface only support adding document files.
But I guess you wanted to instruct your DJs with comments?!
And unfortunately the MusicMaster file interface does not support transporting meta data (like comments) in this interface.
