What is this?
Bumperke
What is this?
Post by Bumperke »
I rebooted the computer now we are not able to voicetrack anymore.
Bumperke
Re: What is this?
Post by Bumperke »
This was on the server side:
16-2-2017 16:44:12 [v4.0.3.5]:********** Error/Exception Information **********
Error Message: Could not create DJPlayer stream! BASS_ERROR_INIT
Error Type: System.Exception
Error Source: ProppFrexx ONAIR.Void DJPlayerInit(ProppFrexx.OutputMixer, System.String, ProppFrexx.Playlist)
at ProppFrexx.DJPlayer.DJPlayerInit(OutputMixer output, String name, Playlist pls)
at ProppFrexx.Playlist.InitPlaylist(Boolean startedByScheduler, Boolean useAlternativeOutput)
at ProppFrexx.ProppFrexx_ONAIR.CreateNewPlaylist(String fileName, Boolean autoStart, String innerPlaylistName, Int32 numPlayers)
at ProppFrexx.ProppFrexx_ONAIR.vq8F(Object , ItemClickEventArgs )
at DevExpress.XtraBars.BarItem.OnClick(BarItemLink link)
at DevExpress.XtraBars.BarButtonItem.OnClick(BarItemLink link)
at DevExpress.XtraBars.BarItemLink.OnLinkClick()
at DevExpress.XtraBars.BarButtonItemLink.OnLinkAction(BarLinkAction action, Object actionArgs)
at DevExpress.XtraBars.ViewInfo.BarSelectionInfo.ClickLink(BarItemLink link)
at DevExpress.XtraBars.ViewInfo.BarSelectionInfo.UnPressLink(BarItemLink link)
at DevExpress.XtraBars.Ribbon.Handler.BaseRibbonHandler.OnUnPressItem(DXMouseEventArgs e, RibbonHitInfo hitInfo)
at DevExpress.XtraBars.Ribbon.Handler.BaseRibbonHandler.OnMouseUp(DXMouseEventArgs e)
at DevExpress.XtraBars.Ribbon.Handler.RibbonHandler.OnMouseUp(DXMouseEventArgs e)
at DevExpress.XtraBars.Ribbon.RibbonControl.OnMouseUp(MouseEventArgs e)
at DevExpress.XtraBars.Ribbon.RibbonControl.WndProc(Message& m)
********** End **********
Rebooted this pc aswell, Not able to voicetrack
Re: What is this?
It seems, you have not updated both side to the same version!
So please make sure, that client and server both use the same PF verison.
Bumperke
Re: What is this?
Post by Bumperke »
That Simple, Thxs
