Bug closing Segue-window in 4.0.3.3
andrerotgans
Post by andrerotgans »
When I use a GPIO/Remote command (SEGUE_CLOSE) to close the segue editor window in the new 4.0.3.3, the screen goes blank but doesn't actually closes.
When after that action I close it myself, it does close. However, when I open it again to edit a new segue, the screen comes up blank again.
The only way to reset after that is to either forcefully close down windows before shutting down PFOA, or (better...) to remove the layout file.
When I close down the segue editor by hand instead of by the SEGUE_CLOSE command in the first step, it just works fine.
I didn't dock the segue editor window because we would like to keep it as a floating window. Maybe that is causing the problem?
Can you reproduce this?
Best regards,
André
Segue editor screen after SEGUE_CLOSE command.png (82.76 KiB) Viewed 9086 times
Command GPIO.png (12.49 KiB) Viewed 9086 times
Re: Bug closing Segue-window in 4.0.3.3
Yes indeed. This will be fixed quickly in the next release.
DennisdeWit
Post by DennisdeWit »
Dear Bernd,
Since update 4.0.3.3 I can not even open the Segue Editor anymore. Should this be fixed in 4.0.3.4 too?
If you couldn't open it anymore because of the above, you need to delete or reset the layout as explained above.
Else there was never any reported issue with opening the Segue Editor.
A v4.0.3.4-beta is available fixing this.
(so "Check for Beta-Versions...")
