My configuration files for Proppfrexx and D&R Airlite
This forum is unmoderated!
rwijnen
Post by rwijnen »
I started of with the files that were allready provided on this forum, so I can't take credit for most of this.
To make it work the way I want it to I changed quite some settings and came up with the following:
Settings Proppfrexx.zip
(6.37 KiB) Downloaded 749 times
IMPORTANT!
Before you start please fully backup your current settings!
Files:
- airlite-config-preset: Load this preset at the airlite configuration manager
- sw.events: Load this events file at the general settings => Events/Commands
- airlite.mixer: ProppFrexx Mixer and Routing for Airlite (C:\Users\YOUR-USERNAME\AppData\Roaming\radio42\ProppFrexx ONAIR\4.0)
- Default.drl: GPIO Remote Mapping for Airlite (C:\Users\YOUR-USERNAME\AppData\Roaming\radio42\ProppFrexx GPIOClient\4.0)
How is the Airlite configured in this sample?
Channel 1-3: Mic
Channel 4: Player A
Channel 5: Player B
Channel 6: PFL player and Overlay player
Channel 7: Cartwall 1 and 2
Channel 8: VoIP / Skype
First row of control buttons 1-8: Cartwall 1 (start / stop)
Second row of control buttons 1-8: Cartwall 2 (start / stop)
When playing the control button will blink fast from red-green, when finished it will be off.
Local soundcard: Monitor signal (same as PFL).
USB 1 Output (Main Out): In 1 at ProppFrexx. This channel has to selected for stream source. Hasn´t to be unmuted. (see page 19 of the airlite manual)
USB 3 Output (Voice Track signal): In 2 at ProppFrexx for voice tracking and pre recording your voice. (see page 19 of the airlite manual)
Installation:
1) Import all files at the right direction.
2) Check your mixer settings and add the correct usb channels of the airlite to your single in- and outputs.
3) Restart ProppFrexx.
RadioMaxDK
Re: My configuration files for Proppfrexx and D&R Airlite
Post by RadioMaxDK »
Thanks! It's really amazing to watch PF play on different faders, and the ON light that goes on and off :-)
One problem: When a new hour starts, Deck A is turned on for a very short while, and then turned off again. I suspect that when the last track from last hour is stopped, the event waits for 500ms, and then turns off the channel.
How to solve this?
Thanks
RadioMaxDK
Problem fixed with this: Starting each hour with Fixed TimeUpdateSync
