Auto-tagging of songs
RadioMaxDK
Post by RadioMaxDK »
Hi.
We're moving 2100 wav-songs to ProppFrexx. But year is missing in the Tag because we haven't entered it.
Is there a program that can search a database and add the missing Tags? (I know it is not a strict PF question)
Thank you!
Re: Auto-tagging of songs
Not that I know of.
atlantic
Post by atlantic »
Maybe with Musicbee http://getmusicbee.com/
I guess the problem will be, that MusicBee might not use the RIFF INFO fields ProppFrexx is using?
Here you can find, what TAGs ProppFrexx is using.
viewtopic.php?f=9&t=7
Alternatively you might create a ProppFrexx .pfp playlist file (which is an xml based format) and then use this to automatically 'transfer' the meta data to the audio files.
The ProppFrexx PFP Playlist Format is an open and publicly available here:
http://www.proppfrexx.radio42.com/download.html
RadioMaxDK
MusicBee tag's actually works nice within PF. Only problem is, that MusicBee often tag with incorrect year from a compilation album, though I uncheck compilation.
I ended up using MusicBee and lot of manual work. Thank you!
