How to change Script lib
rvtienhoven
Post by rvtienhoven »
In the past (i think when we used version 3.x), I had different script categories. Now, all my scripts are onder the Category 'Auto'. The issue is that I can't move scripts from 'auto' to another (new) categorie. Do I something wrong? If I create a new script, I can give it an category, but not for existing scripts...
Re: How to change Script lib
When a script appears under the category "<Auto>", this means, that you have provided a "Script Library Path" - see general settings, section 'Scripts/Scheduler'.
This specifies a directory which contains your scripting files (.pfs). Each .pfs file found will automatically be loaded and available within the scheduler programs.
Scripts added automatically in this way are always getting the Category "<Auto>".
If you want to maintain your script files manually, do NOT use the above entry, but leave it empty!
Then press on the 'Additional Script Libraries...' button and add your script files manually.
This also allows you create and move them to individual categories!
P.S.: Funny, that you don't want to let us see your script names ;-)
