playlist
vsolivie
playlist
Post by vsolivie »
Hi Bernd is it possible to make proppfrexx play a playlist created in the format (m3u8)?
Re: playlist
Yes sure!
Here is the list of supported playlist formats:
PFP, M3U, M3U8, PLS, XML, WPL, ASX, XSPF, SMIL, MLP, DBF, MDB, SQL, plain folder.
(the actual format being used is directly identified by the playlist file extension)
vsolivie
Re: playlist
Post by vsolivie »
OK BERND THANK YOU
