how to remove columns
How can I remove columns? (for example Album, BPM & Bitrate)
- PF.JPG (23.4 KiB) Viewed 4666 times
Re: how to remove columns
I think right click on a column name, in the menu, select column chooser, then drag and drop the column you dont want to the chooser window...
..or just drag the respective column down until a back cross appears and then drop it.
