Finalizer - Import Track
andrerotgans
Post by andrerotgans »
Dear Bernd,
When adding campaigns I use the 'import track' option to add advert tracks. That way everything related to a campaign stays nicely together within the PFOA Ecosystem. When adding a finalizer, to a campaign I have to first manually copy it to the created campaign directory as there is no import option for opener/closer/finalizer.
Would you consider adding that option in a future release?
best regards,
André
Re: Finalizer - Import Track
Why would you need to copy the Finalizer track?
You can directly reference it from within the campaign (without first copying it).
andrerotgans
I know. That's not what I try to say.
I need to copy the file because I would like to have it next to the advert tracks, in it's campaign directory. So I have to copy it first to that directory, before reference it. Otherwise, it would still be in it's original directory (i.e some folder on my desktop)
The ideal situation would be that the finalizer would have the same import option as the advert tracks, so PFOA would take care of that.
andrerotgans
haha, no worries, it's not high on my priority list as well. As said, it would be nice :)
I'll think about it and put it on the wish list; but as a simple yet effective workaround exists...I assume this is not really of high priority. ;-)
